Exporting RHINO Blocks to VWX Symbols WITH 2D Images
How to seamlessly convert VWX Symbols to Rhino Blocks including 2D images and the reverse?So far, I can only import/export geometry and text but the 2D images (jpgs or pngs) do not attach.
I’m an Exhibition Designer who shares exhibition files to other museums for traveling exhibitions and we all work in different software, so I’m constantly running into this issue.
Thanks!
Hi, @Tristan_Telander. I’m assuming you want Rhino blocks <> Vectorworks symbols that keep their materials & texture mapping, correct?
Which filetypes have you tested so far? Have you tried DWG/DXF? Have you tried the Rhino WIP, if you are a Rhino 8 license holder? I don’t have access to Vectorworks to do testing with you, but maybe someone else here does.
Additionally, reply with a Rhino 3DM file with a block that has a material that does not import into Vectorworks, and the same with a Vectorworks VWX file with a material that does not import into Rhino.
