I had to export some coordinate points to a txt file. And I want to transfer the points in the time order they are recorded by the digitizer. I could not figure out if the order of coordinates in the txt file are time sorted or not.
Hello - If you digitize some points and pre-select them (without making any changes to the points) and then Export, there is a chance they will be ordered according to time.
Note that possibly the order is reversed.
-Willem
=) yeah… ambiguous wording was intentional…
Thanks
