Dear Forum
I have a Mesh to which I have applied textures onto. However when I render/raytraced object or export 3d model I loose the textures and colors.
Can you please help me with this issue
Dear Forum
Hello - make sure the .mtl file and the textures are in the same folder as the obj file.
Thank you for your response Pascal. It seems my .mtl and .obj are saved as two different files. Also I used an Image as a Texture and I used the extract Render Mesh command.
Can I please attach the folder, just so you can check that I am doing the right thing ?
