Exporting mesh or polysurface to parasolid(x_t) format
I tried to export both a mesh and polysurface (meshtoNURB) in x_t format.
It gives error in case of mesh and shows waiting for a polysurface (software becomes unresponsive after few seconds).
Please help!
Hello- x_t export does not support meshes at all. MeshToNurbs will no doubt show a warning on the object you show in the image… Did you read it? It is a warning that you are creating a potentially massive and unusable object.
Yes, I saw the warning.
Is there any way to convert it into x_t format in Rhino (given mesh is in .stl)?
Hi Kanika - in general, no - you need to build the object using the mesh as reference - there are plug-ins that can help with this reverse engineering process but it can be difficult and require some skill in surfacing.
