I have a mesh object to which i want to add the dimensions in rhino and export them together as an obj everything I’ve tried export the model but not the dimensions, can anyone suggest a solution. Thanks
I don’t now what you want to do with the dimensions in the receiving software…
You can explode the dimensions and pipe the dimension lines. Explode the dimension text and either make into planar surfaces or extrude to a 3d object.
Thanks Wim that worked
