Exporting dwg - block transformations missing
Hi all, I’m having an issue exporting blocks from rhino as a DWG. Some blocks are losing their transformation data and are exporting to 0,0,0.
When I import the DWG file back into rhino and check the object description it gives me *identity transformation * instead of the transformation value.
Block Instance
transformation:
Can you post an example?
