Exporting cylinder feature to SKP oddly
Not sure if this is a bug or operator error.
The SKP exported from Rhino is tesselating the cylinder walls oddly. Rhino’s 3DS export maintains the cylinder-ness correctly.
The source geometry is Solidworks exported via STEP AP214. I’ve attached all files. The STEP file contains the whole assembly; the other files contain just one part to make comparison easier.
Any help is greatly appreciated.
P1055_AP214.step (2.6 MB)
sidepanel.3dm (4.6 MB)
sidepanel test.zip (2.4 MB)
Hi Peter - thanks, I’ll take a look. Just fyi, running Purge > UnusedBlockDefinitions=Yes on the 3dm file reduces its size from 5MB+ to about .5MB…
Does BlockEdit then Weld at 30 degrees sort out what you’re seeing?
Thanks Pascal, good to know!
