Hey guys came across since uploading files with textures to the forum whether there is an export option to save everything (3dm-files incl textures) into one location?
Thanks a lot!
Hannes
Thanks a lot!
Hannes
Hi Hannes - you can save the textures in the 3dm file with the ‘Save textures’ check box in the save dialog. You can set this in DocmentProperties > Rendering as well.
@pascal as you see here there is only one texture asigned (200MB) seems like there are all textures in the file as well, where can I delete the unused ones?
Hi Hannes - start with Purge to get rid of unused materials - does that help at all?
Perfect! Works!
