Export to .xyz File
Is there a way to export a couple of Points to an .xyz File?
I want to import a point Cloud from Rhino into a Terrain in Archicad
Hello - Export > Points file as the file type
Is that what you mean?
Yes thanks,
I just have to figure out if Archicad wants points or comma,…
the archicad import does not work with .txt file
is there a way to translate it to .xyz?
Hello - you can rename the file extension and it ought to work.
