Export to PDF is not working
I’m struggling to export PDFs from the model space in RhinoWIP:
When I go to File / Export or Export selected and choose PDF from the list, this is all I get:
It is easy to reproduce, it does this with every file, even if you draw a single line in them.
My goal would be to have something useful in Affinity Designer. As it won’t read DWGs at all, and does not recognise Illustrator files created in Rhino, PDF and SVG are my options, but none of them work.
(Yes, SVG export has the exact same error message.)
Hello - thanks, I’ll check it.
Yep, use Print for now, guess - Export should get you the same, more or less, interface as the print interface.
https://mcneel.myjetbrains.com/youtrack/issue/RH-45057
