I want to export parasolid file using c#. need a c# sample code to export parasolid file.
Hi @sonamkumar.eng,
The only way to export .x_t is to script Rhino’s Export
command using RhinoApp.RunScript
Here is an example of how to export dxf you can use as a starting point.
– Dale
