Export to AI uses display color not print color
How do I go about exporting to an illustrator file so that the print color is preserved rather than the display or layer color? I need to keep the layers in their current state (can’t move objects to other layers or change layer colors) Since ‘SelColor’ seems to select the color based on the display I can’t quickly ad hoc it to export, and I really don’t want to spend the next day reorganizing this file just so I can export it.
Does anyone have a way around this?
Hello - is PDF OK? That is essentially the more up to date AI format - I’d use export to PDF, as vector - there you can set the print to use print color:
Hmm, it didn’t work on the Mac version (the pdf, even when the mask was released was an image) but sure enough, it worked on the PC version. Thanks!
