Hmm, a previous post led me to find my STL export scripts for V5 are no longer valid for V6 - as the command line options have again been revamped… With a small moment…
Some of the settings seem a bit mixed up (to me anyway)…
First level (after Browse and setting export type to STL and giving the file a name):
Next level down (caused by UseSimpleDialog=No and UseSimpleParameters=No):
However, hitting Enter after that exports the object - but what happened to MinimumEdgeLength, as well as RefineMesh, JaggedSeams, SimplePlanes, PackTextures?
Then I figure out if I set UseSimpleParameters to Yes, then I get the following:
Clicking on DetailedOptions gets me:
Which has most of the above missing settings
And AdvancedOptions which gets me finally:
-including the missing MinEdgeLength setting…
But isn’t the SimpleParameters option inverted? I would think when it’s set to No, you would get the more detailed settings.
And why isn’t MinEdgeLength available in MeshSettings when UseSimpleDialog=No and UseSimpleParameters=No?
Once again, this is a really convoluted workflow to have to macro/script…
