Hi
I would like to get the script that recreates the objects on a given layer, is this possible?
For example, I created a cylinder and a box on layer 1, than I want to get the script that
Kind regards
Taoufik
Hi
Kind regards
Taoufik
Example:
A. On layer 1:
B. generate script:
As you can see the move and resize commands do not show in the script
C. Run script on Layer 2
Layer 1 and Layer 2 must look the same
Is this possible using python?
I have a Rhino5 on Mac
Thanks
Can I summarise by stating you want to copy objects from one layer to another?
-Willem
Hi
Thank you for replying
I would like to create a script with the commands, then I would like to
modify some
parameters (ie. dimensions of a box) before recreating the objects in
another layer
Kind regards
Taoufik
I think in some way it’s possible what you want but you would need to explicitly define and set all parameters of the objects. Do you know grasshopper? It seems this might be a better tool for your need?
-Willem
Hi
I am using Rhino5 on Mac, and I think that grasshopper does not work on Mac
Is there a way to access to the commands history? do the commands contain
all the parameters of the command (ie. center of circle, radius, …)?
Kind regards
Taoufik
Indeed you are right…
No unfortunately not.
So a script would have to set all parameters, there is not really a way to record the actions from regular commands.
-Willem
Hi
I do not understand why the command history do not contain all the parameters for each command
executed. is it possible for Rhino to add such thing (this should be easy for Rhino developers)?
The issue, is that when I want to modify a tiny thing in the whole design, I have to redraw everything
Starting from a python script is more difficult, I prefer to draw under Rhino using modifiable
parameters (all numerical values could be replaced by expressions using variables).
I wish I could do the following:
Cylinder
base of cylinder: x=0,y=0,0
Diameter: d=10
end of cylinder: 10
Then when I set x=1, all objects that depend on x are redrawn using the new x value
Kind regards
Taoufik
Because Rhino is not a parametric modeler… Objects do not “remember” how/where they are originally created. The command history is just a collected “printout” of what the command line has had in it for the last n lines.
No, not really. It would actually require a complete restructuring of how objects are created and stored in memory.
However, as Willem already said, it is possible to create a script that would ask for certain parameters and create a specific set of objects based on those parameters.
–Mitch
How do I do that? could you please give me an example?
Kind regards
Taoufik
Below is a rather dumb example… Adds a cube with spheres in all corners to the file. User specifies cube side length, sphere diameter, placement of the center of the object, and a layer for the new object to go to. Run it several times to create different sized objects.
The code is posted below for reading, to test, download the .py file below and save it to your desktop, then type RunPythonScript and brose to the file on the desktop and run.
CreateCubeSphereCorners.py (1.6 KB)
def CreateCubeSphereCorners():
#for minimum sizes bigger than file tolerance
tol=rs.UnitAbsoluteTolerance()
#get user input
cub_side=rs.GetReal("Cube side length?",10,tol)
if cub_side is None: return
cr=cub_side/2
sph_dia=rs.GetReal("sphere diameter?",cr,minimum=tol,maximum=(2*cr)-tol)
if sph_dia is None: return
bc=rs.GetPoint("Pick point for center of cube")
if not bc: return
#ask user for a layer (possible to create new one)
#also possible to automatically create a new layer
layer=rs.GetLayer("Layer for object?",rs.CurrentLayer(),True)
if not layer: return
#cut screen redraw to go faster
rs.EnableRedraw(False)
#calculate box corner points
corners=[]
corners.append(rs.coerce3dpoint([bc.X-cr,bc.Y-cr,bc.Z-cr]))
corners.append(rs.coerce3dpoint([bc.X+cr,bc.Y-cr,bc.Z-cr]))
corners.append(rs.coerce3dpoint([bc.X+cr,bc.Y+cr,bc.Z-cr]))
corners.append(rs.coerce3dpoint([bc.X-cr,bc.Y+cr,bc.Z-cr]))
corners.append(rs.coerce3dpoint([bc.X-cr,bc.Y-cr,bc.Z+cr]))
corners.append(rs.coerce3dpoint([bc.X+cr,bc.Y-cr,bc.Z+cr]))
corners.append(rs.coerce3dpoint([bc.X+cr,bc.Y+cr,bc.Z+cr]))
corners.append(rs.coerce3dpoint([bc.X-cr,bc.Y+cr,bc.Z+cr]))
#add box
cub=rs.AddBox(corners)
#add spheres at corner points
spheres=[rs.AddSphere(pt,sph_dia/2) for pt in corners]
#Boolean union all
spheres.append(cub)
uni=rs.BooleanUnion(spheres,True)
#move object to desired layer
rs.ObjectLayer(uni,layer)
