There is a small export bug currently where it gets stuck if the model contains no parameters. This will be fixed soon. In the meantime, adding a parameter to your model should fix the issue.
Great! That takes care of this little example.
Even without adding some parameters it’s possible to use the ShapeDiverExportDownload component.
Now I can do the real test which is to group my 5 curves.
But that does not work with either of the ExportEmail or the ExportDownload components, even if I add a parameter.
