Export or convert stl to stp
is there a good way to convert an stl to a stp or similar format?
It all depends on the stl. If the stl is an organic object, a QuadRemesh > SubD > Nurbs workflow might work. If possible share a model that you want to convert. If it is confidential, you can upload it here and send a reference to this thread.
thanks! it was an stl that i created using a 2d drawing and i couldn’t find the 2d drawing to redo it, but i found ExtractMeshEdges to use on the stl.
but then i tried the QuadRemesh > SubD > Nurbs on an stl and exported as a stp, worked great.
Thanks!
solved ?
please mark Gijs answer as solution.
thanks
