I am having an issue exporting 2D from Rhino Beta (9.0.26258.12303, 9/15/2026) into either Rhino V8 or Bricscad (AutoCad clone). I first create using the “Make 2-D Drawing” command from the pull down menu, select the items I want to create a 2D of (which correctly makes the 2D I want to export), then export using my custom scheme “MyDefault”, which I have used in previous versions of Rhino. Here are my settings:
This looks like a bug in the Rhino 9 Beta DWG/DXF exporter: the “Simplify tolerance” value from your export scheme wasn’t being used, so a much looser tolerance was applied and the small fillets were simplified into straight lines. It’s been fixed (RH-98711), and the fix should be in the next Beta build.
Until then, you can work around it by unchecking “Simplify lines & arcs” on the Curves tab of your MyDefault scheme. Curves will then be exported as lines using your 2° maximum-angle setting.
If you can share the model (or just the Make2D output), I’d like to check it against the fixed build to be sure.
