Export objects with the origin in the right place
Is it possible to change the origin of an object? I am creating objects that I want to spin around their center. I create an object in Rhino, centered on 0,0,0 and export it as an obj file and I import this object into Daz studio, and the origin point of the object is in the wrong place. I want it to be in the geographic center of the object, but apparently rhino puts the origin for extrusions on the bottom. This screws up any animation where I want an object spinning around its center. Daz does not have the ability to change the origin since it’s not a modeler, so how do I change an object’s origin in Rhino?
When exporting an OBJ file, there is an option Map OBJ to Rhino Z. Did you have it checked? If not, pls try checking it.
