Export into Illustrator Bug
I think I found a bug in Rhino 7&8. If you want to export a file in Illustrator, the “AI Export Options” window always appears. I’ve never switched anything else there and everything worked when exporting.
But when I selected the “Preserve model scale” option, it was retained regardless of whether the check mark was there or not. In addition, the box no longer turns light gray like before.
I have already tried to reinstall the program but all the settings are retained.
Hi Jan - if I understand, once you set Preserve Model Scale once, the option seems to stay active even if it appears not to be selected, is that correct?
Hi Pascal,
Thanks for the fast reply.
Yes. A friend of mine has the same problem and we both use the testversion.
-Jan
hi @Jan_Schmitt I canno reproduce that here on my Mac,
pls run _SystemInfo in Rhino and post back the results
Sorry for my late response, the mail was stuck in my spam.
The problem is still the same but I got used to it and have found ways
to work around the bug.
I just have to change the model scale if I want to export the file to
illustrator. It may take 1 or 2 trys but it works.
So if you don’t find a solution it’s not a big deal anymore.
Thanks for your support.
SystemInfo.txt (4.09 KB)
