Export in pdf - ShapeDiver + Squid
Hi SD team,
I am exporting pdf using SquidPDF and download export. The image I export should have rectangles (as I am exporting rectangles as polylines) but when you zoom on the pdf you can see that the rectangles have round corners. Is there a way to get “perfect” rectangles? does it have something to do with the export options?
Attached some screenshots and .gh file.
Image_pixels.gh (30.0 KB)
Our team is looking into this issue and will get back to you as soon as we know more.
It looks like this problem happens because the outline is too thick. When it is being drawn, what you see is the stroke radius. If you put the outline width to 0, then this should give you perfect rectangles with corners.
Great, it solves my problem thank you!
