Export grasshopper / rhino to DWG
Hello everybody,
I have an issue regarding DWG Export from rhino. So, I have made this script that is generating tiling plans using python component in grasshopper and then I bake that grid on a separate layer in Rhino (visible on this screenshot below)
When I take that same grid from rhino and I try to export it to dwg format for some reason the edges end up deformed (visible on this screenshot below)
this is my code:
110526.gh (137.6 KB)
Updated:
  • I have fixed this issue by using Curve to Polyline tool. I assume that the issue was the tollerance that exporting to dwg would require.
