Export from 3.6 to 3.4
Hi, I need to pack my scene (V Ray 3.6) for other pc with V Ray 3.4. Is this even possible? The 3.4 PC is not capable of working properly with it.
Any suggestions?
At first, it is important to know that which OS PC you are using now. If you are using the Mac computer, then it is possible to pack your scene with V Ray 3.6 for other PC with V Ray 3.4. You can do it easily by knowing the ways from Apple iPhone Support as they provided me the proper way to do it. So I can suggest you ask them too and can solve your issue easily.
V-Ray for Rhino is not backward compatible. There is no guarantee all V-Ray data created using the latest build will be properly read when opened with an older version of V-Ray.
The latest V-Ray update, v.3.60.03, is available for free to all V-Ray 3 users. To avoid any compatibility issues, my recommendation is to use it on both machines.
Kind regards,
Peter Chaushev
V-Ray for Rhino QA
www.chaosgroup.com
P.S. ignore the spam post above mine.
