Export DWG
what are the prerequisits of exporting the dwg in plan cut? Does one need to use the level editor / levels provided by VisualARQ? I am trying to export something with just regular CPlanes, but it shows the volume from above in the exported dwg.
Thanks, Petr
Hi @Petr_Tuma the main requirement to export a page layout to DWG is to use the Hidden display mode inside the Detail views. If you want to show one level or another, you need play with level settings in the Level Manager. And if you want to show the model from a vertical section, you can use VisualARQ sections and activate them from the Section Manager. Check this video: https://youtu.be/1BhuBbS9gNs?si=ZhEkYG3B7u_zkPYr
