Export curves to DXF using the active CPlane?
How can I do this?
The curves end up in the DXF relative to the world plane instead of the currently active CPlane.
Current workaround is to draw a crosshair of lines in the CPlane origin and then use the orient tool to translate the curves to the world plane, but that’s a hassle.
Hello - there is a setting in the export schemes to control this -
Perfect, thank you!
(Since there’s so many other tools in Rhino that doesn’t have this option, I did not think to look this time when there actually was one…)
