Export and optimization
I decided to crate freeform gridshell with rhino and grasshopper And do the optimization process on it with MATLAM
I need for the coordinates of the points and the nodes that connect.
how to get it
Please advice me
https://discourse.mcneel.com/t/how-to-ask-effective-questions/50034/2
Hi can you explain your intended process in more detail?
Can you share a sample file?
What format would you like to output the data in?
Hi Thanks for reply
Suppose I have a gridshell
now I need all the grid points with coordinates x, y, x(all nodes).(like Excel file)
also I have to know about Number of each node, Which nods are connected together
thanks
OK I see. How about saving it as an stl file? That should contain the connectivity info and I imagine there must be a Matlab importer for stl out there somewhere…?
I have stl sample file like this attached file but i cant import to matlab,
test.stl (76.3 KB)
I’m looking for a way to import the file to MATLAB and I can to have access to the points,
if I have coordinates and connectivity info i can write program in MATLAB for read points and create form again and continue…
now if you know another way please advice me
Hi does this work?
Hi Dear friend,
I thinks, its good, I will try test this way and answer my result at this here,
also I found a good guid file like your Idea
Thanks
Lecture 19 – Interfacing MATLAB with CAD.pdf (3.5 MB)
hi,
I test it but only whit this way I can open file and get a photo like this attached file,my original file with STL format is gridshell,
I can not see gridshell and points and the nodes that connect.
also I find in MATLAB information following:
FV = STLREAD(FILENAME) imports triangular faces from the binary STL file
indicated by FILENAME, and returns the patch struct FV, with fields ‘faces’
and ‘vertices’.
[F,V] = STLREAD(FILENAME) returns the faces F and vertices V separately.
[F,V,N] = STLREAD(FILENAME) also returns the face normal vectors.
tt
test.stl (76.3 KB)
