I have a script for exporting to acis files. Only wish is if this script only exporting the layers that are on. I have also layers off with contains cad lines, or differents options of objects. This should not be exported.
Now I do it manuelly because of this. But it takes more time and I have to do this over and over again…
Does anyone knows how to do this?
Thanks in advance.
Don’t know how your script is written, but normally _Export can only export selectable objects, which can only be on layers that are visible. So your script should be written with _Export and not with _SaveAs (which will save the whole file). You will need to select all visible/selectable objects before running the export, this can be accomplished in various ways in the script.
HTH, --Mitch
Thanks, I’m not very familiar with scripting, I didn’t writen this script. But I can check if this is the case.
The script I was talking about was the one on the Mcneel site https://wiki.mcneel.com/developer/scriptsamples/exportlayerobjects
I used this script in the past, but then it turned all the layers on and export also the hiden layers. For some reason I get an error now.
What I like to have is a script so I can easily export all the selected objects in layers (each layer a sat file). It would be even more beautiful if I can give the location.
Thank you.
Old python script i used for this problem.
#Export multiple sat for every layer (It works only with surfaces)
if __name__ == "__main__":
# collect all object
objs = rs.GetObjects()
# export folder
folder_path = rs.BrowseForFolder(message = "Select folder for the export:", title = "Multiple SAT exporting")
# collect all the layer id
lay_ids = rs.LayerIds()
rs.UnselectAllObjects()
for i, lay_id in enumerate(lay_ids):
# extract layer name
lay_name = rs.LayerName(lay_id)
# print( rs.LayerName(lay_id) )
for obj in objs:
if(rs.ObjectLayer(obj) == lay_name):
rs.SelectObject(obj)
# export
file_name = "NAME_{}".format(i + 1)
exp = "-_Export {}\{}.sat ACIS Export Type Default _Enter".format(folder_path, file_name)
rs.Command(exp)
