Exploring This Fillet Problem
Hello All,
I am having this issue with fillets in the highlighted areas. I am trying to explore how to fillet this region, and nothing seems to stick. If anyone has ideas on how I can tackle this area, please let me know.
I have tried a few things, but I cannot seem to get a nice flowing continuity.
Thank You.
Question For Fillet.3dm (339.1 KB)
FilletEdge results in this which is valid without any naked edges:
I’m guessing you want something different. What do you want? If you were given a physical part like this, a file to remove material and clay to add material, what would you do? In other words what is your design intent? Or do you need a design intent?
You need to think about what shall happen in these regions.
Question For Fillet.3dm (2.4 MB)
I would use FilletSrf. Do it Like this: Question For FilletX.3dm (327.6 KB)
This is one way how you could treat this region: FilletSrf > Extend > BlendCrv G2 > EdgeSrf > Match G2 > Match G2 OnSurface > Trim > bit o’ CP pulling for good G2.
Flipping G2 fillet.3dm (477.1 KB)
You can see a similar approach here, too:
P.S. The better way to match to a surface is to not trim the target surfaces at all, and instead use ā€œMatch surfaceā€ with the ā€œOnSurfaceā€ command line option. That way, the resulting surface will require far less control points and if you split it into 2-3 pieces and shrink them, convert them to Bezier and match again each one individually, you can achieve single-span surfaces.
@Rhino_Bulgaria Your method in the tutorial video is quite creative — I’ve never seen it done that way before. Ingenious… I’ll probably try it in one of my next projects, even just to test it out. :wink:
I had a better video with a much cleaner result, similar to what @Lagom showered above, but I can’t find it at the moment. I used the ā€œOnSurfaceā€ option there, whereas my two older videos above show regular matching to split surfaces.
A similar technique is also used to fill 5-sided holes.
My two videos show two different techniques:
  1. From edge to edge;
  2. From corner to corner diagonally.
just to add to the discussion - there is always 2 hierarchies if you follow the approach shown above:
green first
the green rolling ball / sphere is doing its job first,
then the violett, second ball/sphere is on top of it
violett first
reversed order
EDIT
other typology
i did not fiddle it till perfection - but to show the concept i like most from a academic point of view:
main steps:
(1) rebuild all neigbouring surfaces as non-rational.
current implementation of _matchSrf i missbehaving with ā€œarc-styleā€ (rational) surfaces.
(2) start with a simple loft
keep this surface as reference, split a copy into the 4 pieces.
(3) do several _matchSrf, optional changedegree / insert knot… cv massage… always feels a bit like alchemy
(4) vote for improvements in _matchSrf or use Wip 9 patch command as workaround
Thank You all for these creative solutions, I am going to apply them and get back with some more questions if that’s ok. Really appreciate your input.
These videos are incredibly helpful and I have followed your channel. Thank you!
I am trying to follow this but I use Rhino 7 so I am trying to follow your instructions. Thank you!
