Exploding dimensions
@lowell, when exploding a dimension in the latest WIP, the dimension lines are not created. The arrow heads and extension lines are fine, it’s just the dimension lines that are missing. I don’t know if this is on your plate…
@wim They are present in my default setting with the dim above the line. But when I switched to inch decimal and changed to the dim in the dim line they are missing when exploded
Thanks. I see that here too. I’ll see what I can find
That seems to be working here in the latest…
