Hi!
Feature request (if not on the list already): when exploding a vaPlanView, the 2d blocks of the vaFurniture should be kept as blocks, for convenience of those people that need to work on those plans in 2D.
Is this doable?
Thanks a lot!
Hi @Eugen,
Yes, there is a request, I will add your vote!
By block maybe its difficult because the representation of the same object can change depending on how it is positioned and also be affected by other objects around, which can lead to have several block definitions for the same object. But we will think about it.
An idea is to use groups, for example group all the curves that correspond to a chair. And also to have the possibility to preserve the source layers structure, similar to the options that the Rhino Make2D offers.
Kind regards
