Explode Blocks without Exploding the Nested Blocks
Hi All,
Does anyone know how to explode a block without exploding all the blocks inside of it?
Thanks!
Hi Max,
Use the regular command _Explode to explode a block into it’s top level components.
HTH
-Willem
Better is blockedit
You can access to sub blocks, modify it and go back to upper block whitout breaking the structure and modifying all the instances.
AHHH! Thanks!!!
