I have a grid of about 7000 circles. There 7 different circle sizes. Each of the seven circles is a separate block.The grid is a 1" x 1" sq pattern.
The client now wants the same file but 3 times larger. If I just expand the file by 3 everything will be visually correct but the original block definitions will still be 1/3 the new size. Which will cause me problems down the road.
Ideally I would like to expand the grid and expand the position of each of the blocks so they would all now sit on a 3" grid. I could then go into the block definitions and scale them each up by 3 and then everything would be correct.
But I can’t figure out how to do that. Is it possible? Or is it painfully obvious and I’m too tired to see it?
Thanks for any suggestions you have.
