ExecuteCommand issue
Hi - I have a python script and want to run one of my plugin commands from it. The code is…
Rhino.RhinoApp.ExecuteCommand(Rhino.RhinoDoc.ActiveDoc, "OctaneChangePinValue environment:texture:projection:transform:rotation 21")
This gives an error in the Rhino command area as follows:
Unknown command: _OctaneChangePinValue environment:texture:projection:transform:rotation 21
However if I just type the command in to the command line, it works fine:
Gives…
Command: OctaneChangePinValue
Enter pin name: environment:texture:projection:transform:rotation
Enter pin value: 21
How do I fix this please?
Thanks
Paul
Hi @pkinnane , you could try
Rhino.RhinoApp.RunScript("OctaneChangePinValue environment:texture:projection:transform:rotation 21", True)
Thanks Darryl - that works.
Paul
