I’m pulling curve/line lengths from closed curves, writing a script to lay out a pattern for bending aluminum around CNC’d plywood forms, I need to add a little tolerance at the bending points but not the ends, where it meets perfectly and gets welded.
I can’t just ignore lines 0 and 6 every-time because I have many different shapes with different breaks. I need to somehow only add to the center items, in this example, 1-5.
That was perfect thanks. I realized I needed to give the ends half the tolerance to still get full tolerance on all the bends. Was able to slip that in easily.
