I have a mesh that I created from a manually drawn surface in Rhino. Then I used “DiagonalizeMesh” component to convert the rectangular grid to diagonal. I would like to select all the grid edges (in this case all the diagonal) except of the outer perimeter ones (parallel to X and Y coordinates).
I am still new to Grasshopper environment and would highly appreciate if someone can suggest a way of doing this.
It seems to use slightly different vertices for the mesh creation. I would call this a bug. Maybe @DanielPiker knows(and cares :)) why this is happening.
Also Petras’ version seems to suffer from this but less(you can see by zooming in) So probably all this is also a tolerance issue.
Here my clumsy C# attempt(if someone cares):
