I would like to ask if there an example how to:
Check if a layer with a certain name exists
If not create layer
Then add objects to that layer
Currently I am baking objects while adding them to and I would like to add those groups to a specific layer:
for (auto& output : output_polyline_groups) {
ON_SimpleArray<const CRhinoObject*> group_members(output.size());
for (int i = 0; i < output.size(); i++) {
ON_3dPointArray points;
points.Reserve(output[i].size());
for (size_t j = 0; j < output[i].size(); j++)
points.Append(ON_3dPoint(output[i][j].hx(), output[i][j].hy(), output[i][j].hz()));
ON_Polyline pline(points);
CRhinoCurveObject* curve_object = context.m_doc.AddCurveObject(pline);
group_members.Append(curve_object);
int group_index = context.m_doc.m_group_table.AddGroup(ON_Group(), group_members);
if (group_index < 0) CRhinoCommand::failure;
dale
(Dale Fugier)
November 22, 2021, 5:27pm
2
Maybe something like this?
static int RhinoFindOrCreateLayer(CRhinoDoc& doc, const wchar_t* layer_name)
if (nullptr == layer_name || 0 == layer_name[0])
return ON_UNSET_INT_INDEX;
int layer_index = doc.m_layer_table.FindLayerFromFullPathName(layer_name, ON_UNSET_INT_INDEX);
if (layer_index == ON_UNSET_INT_INDEX)
ON_Layer layer;
layer.SetName(layer_name);
layer_index = doc.m_layer_table.AddLayer(layer);
return layer_index;
CRhinoCommand::result CCommandTest::RunCommand(const CRhinoCommandContext& context)
const wchar_t* layer_name = L"MyLayer";
int layer_index = RhinoFindOrCreateLayer(context.m_doc, layer_name);
return CRhinoCommand::failure;
ON_3dmObjectAttributes attributes;
context.m_doc.GetDefaultObjectAttributes(attributes);
attributes.m_layer_index = layer_index;
ON_Circle circle(ON_Plane::World_xy, 5.0);
ON_ArcCurve arc_curve(circle);
context.m_doc.AddCurveObject(arc_curve, &attributes);
context.m_doc.Redraw();
return CRhinoCommand::success;
– Dale
Works perfectly thank you.
Dear @Dale ,
How can I hide the previously main layer (change its visibility) after creating a new layer?
I tried to do a) retrieve current layer index, then set a current layer to newly created layer, and then hide the previously active layer, but this does not change the layer visibility:
int current_layer_index = doc.m_layer_table.CurrentLayerIndex();
doc.m_layer_table.SetCurrentLayerIndex(layer_index,true);
ON_Layer layer_current = doc.m_layer_table[current_layer_index];
layer_current.SetVisible(false);
layer_current.SetPersistentVisibility(false);
doc.m_layer_table.ModifyLayer(layer_current, current_layer_index, true);
Full code:
inline int RhinoFindOrCreateLayer(CRhinoDoc& doc, const wchar_t* layer_name) {
if (layer_index == ON_UNSET_INT_INDEX) {
ON_Layer layer;
layer.SetColor(ON_Color(255, 0, 0));
layer.SetPlotColor(ON_Color(255, 0, 0));
return layer_index;
Hmm, this actually works.
Is any method to hide all layers except the current one?
