Hi, I am using GLSLShader to create some custom shading. I would like to set up an event handler to watch the Light.Direction Property. Whenever the Light.Direction changes, it should triggers a method I have.
How should I do it?
Thank you in advance.
RhinoDoc.LightTableEvent += Utils.UpdateLightDirection;
I just tried this, but it doesn’t detect change/modification in Sun nor Skylight.
Will post my research if I know the answer.
EDIT: A further research shows there is actually a EventHandler for Sun
Rhino.Render.Sun.Changed += Utils.UpdateLightDirection;
This is how I solved the problem.
