Even subdivision / panelization of complex SubD geometry by real distance
Test.3dm (148.0 KB)
I’m trying to panelize a complex SubD form into evenly spaced panels.
My current approach was to generate contour curves in multiple directions, compute their intersections, and then use
those points to build a grid. However, due to the complexity of the geometry, this method generates many unwanted intersection points, short segments, and inconsistent topology that require heavy cleanup.
What I’m looking for is a robust way to subdivide a freeform SubD surface into panels with equal spacing (based on real-world distance rather than UV domain).
Is there a recommended workflow for this?
Possible approaches I’m considering:
  • PanelingTools
  • Converting SubD to mesh and using remeshing
  • Rebuilding or reparameterizing the surface
  • Any Grasshopper-native method for equal subdivision of complex forms
I’ve been struggling with this for a while, so any guidance or example definitions would be extremely helpful.
Thanks in advance!
Please attach your gh file
Here’s what i have with Paneling Tools
notice how the gap widens, because the surface is not single continuity, and had protrusion:
SubdDivide_00.gh (13.6 KB)
there is no grasshopper file, but it looks like what you need!! Thanks
gh file is between 2 images
You misunderstood, I don’t have my file. I found yours, thank you again. But for some reason, C# doesn’t want to load
You can replace c# with IAC plug in. It just uses rhinoommon method to convert from subd to nurbs. Or you can do it in rhino, and reference surface instead of subd to grasshopper
