Is there a way to space points of a line evenly across it? So if i rebuild a straight line with 5 points let’s say, they are evenly spaced out… ?
Thanks!
Thanks!
Does the Divide command help?
http://docs.mcneel.com/rhino/5/help/en-us/commands/divide.htm
Hi Dale, Unfortunately no.
I was hoping to rebuild a curve evenly and use the points to control the line in an even behavior. .
Hi Josh - if it is a line, and you want more and evenly distributed control points, use ChangeDegree (up to degree 5, I’d say; after that, Rebuild)
ok great, i will check it out. Thanks for the tip.
