Umm. Something seems to be off with the Evaluate Point Unit Display. The Rhino units are set to inches Decimal, but when I use the evaluate point, with the dot option, it shows in feet & inches. FYI the command line read properly.
Hi Dennis - I see this as well. It is correct as far as I can see in V6/WIP…
Thanks. As a work around I just copied the text from the command line and put it into the annotation dot.
I have the opposite problem. I have units set to display in feet and inches but the EvaluatePoint dot displays in decimal. V6 SR4 2018-5-4
