This is maybe problem with the number slider, it has to allow more digits behind the decimal point. at least to match the capabilities of Grasshopper.
hmm, no answer?
I don’t see a question…
Looks to me as everything behaves as expected?
Also the parameter domain has nothing to do with the curve length.
you don’t need to round since the remap component has a second output called “Clipped”, which prevents remapped numbers being outside of the target domain/interval. This is also known as “clamping”
That also prevents me to get to the end of the interval. It clips at the last value before the end. I see that as a problem.
(I don’t have Rhino in front of me now, but I’m pretty sure that was the behavior. Will check later this evening)
Apparently I was mistaken.
