Good morning,
New member here.
I’m thinking of going into the marine flooring business and have a few questions.
Does Rhino work good with a Prodim Proliner?
Can Rhino be used to design the lines and graphics on the inside of the template so I can send the file to a CNC machine to cut it.
Are there any good links you may have that would help me along?
here is a video where you can see using that tool and Rhino:
I didn’t know that tool existed, is pretty interesting, thanks for the tip.
Thanks Diego,
I got that far, I need to learn how to design the lines inside the template ton get it ready for templating
I think you need to have, a well defined perimeter and then, use the lowest amount of cross sections, like any surface creation, the fewer sections, the smoother result.
