Euglena Computer Vision Plugin for Grasshopper
Euglena is an open-source computer vision plugin for Grasshopper that utilizes the Google Mediapipe framework. With this integration, the plugin can analyze facial features, track hand gestures, and perform other advanced computer vision tasks within the Grasshopper environment.
Awesome! This opens up a lot of interesting use cases. Thank you!
This looks very interesting.
Do you think you may consider adding a Mac package to Mediapipe…?
thanks a lot
akash
Sure
Thank you very much for your suggestion. We are working on it for sure.
Awesome Plug-In! Had an issue installing it on Rhino 8 SR2 - Got an “User Object failed to deserialize” error after following he installing instructions. Could it be that this is an issue related to versioning as the Plug-in was created before Rhino 8 was released? Is there anything I can do instead of installing an older version of Rhino? Thanks for your help
Thank you @Michael_Wieser. Yeah, version compatibility seems to be the issue.This will be fixed in a new version by tomorrow.
Amazing! Thanks for your quick reply :pray:
Euglena plugin is now updated and works with Rhino 8’s latest release. Big thanks to @eirannejad for his invaluable help and guidance!
Looks great!!
Interesting, what are you using these tools for?
@Mahdiyar is there a component which can import data from an Intel Realsense D455 camera in real time?
Thanks so much
This is a great tool
I tried to replicate the definition, as seen on the video (minutee 12:25) but, for some reason the Map to Bitmap returns an error
Can you tell me how to fix this?
any ideas anyone???
