Dale,
I’ve included my final code below that worked perfectly in tiling my userform to the left of Rhino and it opens the same way on my External Monitor and High Res Laptop. I threw in some other macros that work together. GetWorkArea will get the working area of the main screen and also return the taskbar size, PPP returns the pixel density of the main screen, GetRect is your function for getting the size of the Rhino Window, and SetWindowPos resizes and relocates the Rhino Window so the userform and the Rhino Window tile side by side. Thought maybe someone else could use the code so I shared it all.
Many thanks again.
Eric
def GetWorkArea(self):
"""Get working area for monitor. Returns Top,Bottom,Left,Right"""
import ctypes
SPI_GETWORKAREA=48
class RECT(ctypes.Structure):
_fields_ = [('left',ctypes.c_ulong),
('top',ctypes.c_ulong),
('right',ctypes.c_ulong),
('bottom',ctypes.c_ulong)]
x = ctypes.windll.user32
r = RECT()
x.SystemParametersInfoA(SPI_GETWORKAREA,0,ctypes.byref(r),0)
retvals = [r.top,r.bottom,r.left,r.right]
#Calc Height of Userform and Set##############################
size = rs.ScreenSize()#X,Y
work = retvals#GetWorkArea()#Top,Bottom,Right,Left
tBar = size[1]-abs(work[0] - work[1])
UF_H = size[1] - (tBar*2)
self.ClientSize = drawing.Size(UF_W,UF_H) #sets the (Width, Height)(Optional only)
return work,tBar
@staticmethod
def PPP():
"""Gets the Screen Resolution and Pixel Density"""
from ctypes import *
CreateDC = windll.gdi32.CreateDCA
GetDeviceCaps = windll.gdi32.GetDeviceCaps
NULL = c_int(0)
HORZRES = c_int(8)
VERTRES = c_int(10)
LOGPIXELSX = 88
POINTS_PER_INCH = 72
screen = CreateDC(c_char_p("DISPLAY"),NULL,NULL,NULL)
x = GetDeviceCaps(screen,HORZRES)
y = GetDeviceCaps(screen,VERTRES)
lDotsPerInch = GetDeviceCaps(screen,LOGPIXELSX)
PointsPerPixel = float(POINTS_PER_INCH) / float(lDotsPerInch)
# x = x * PointsPerPixel
# y = y * PointsPerPixel
return lDotsPerInch,x,y
@staticmethod
def GetRect():
"""Gets the size of the Rhino Parent Window"""
import ctypes
from ctypes import wintypes
hwnd = Rhino.RhinoApp.MainWindowHandle()
rect = wintypes.RECT()
ctypes.windll.user32.GetWindowRect(hwnd, ctypes.byref(rect))
width = rect.right - rect.left
height = rect.bottom - rect.top
return rect.top,rect.bottom,rect.left,rect.right,width,height
@staticmethod
def SetWindowPos(x=0,y=0,w=0,h=0):
"""Sets Window Position for Left and Top and Size of Window (width,height)"""
HWND_TOPMOST = c_int(-1)
HWND_NOTOPMOST = c_int(-2)
SWP_NOMOVE = 0x02
SWP_NOSIZE = 0x01
TOGGLE_HIDEWINDOW = 0x80
TOGGLE_UNHIDEWINDOW = 0x40
SetWindowPos = windll.user32.SetWindowPos
SetWindowPos(rs.WindowHandle(),HWND_TOPMOST, x, y, w, h, TOGGLE_UNHIDEWINDOW)
