Hi @curtisw,
nice little dialog, that holds almost everything needed for a about dialog. One more thing to set as a property would be to control the windows icon. Would it be possible to add this?
Would be great.
Thanks
Christian
Hi @curtisw,
Would be great.
Thanks
Christian
Not without skinning Rhino.
β Dale
@Christian_Hartz, you should be able to modify the window icon with something like this:
var aboutDialog = new AboutDialog();
if (aboutDialog.Handler is Eto.Forms.ThemedControls.ThemedAboutHandler handler)
handler.Control.Icon = my_icon;
Note that the icon must be loaded from an .ico file for it to work currently.
Hope this helps!
Well. Thanks for that. Little correction:
if (aboutDialog.Handler is Eto.Forms.ThemedControls.ThemedAboutDialogHandler handler)
handler.Control.Icon = icon;
Kindest
Christian
Hi Guys,
Is there a way to launch the AboutDialog non-blocking so I can use it as a loading splash screen while a python script runs in the background?
Cheers
DK
Hey,
dont think so. You would need to make your own Eto.Forms.Form
or something similar, I guess.
Kindest
Christian
@Christian_Hartz thanks - bit of a pain to get this far and see that.
@dale is there any way to possibly overwrite the AboutDialog class to be semi-model?
Cheers
DK
@kiteboardshaper There is no way currently to make the AboutDialog semi-modal or modeless.
You have a few options. First, you could do something like this to run your script while the dialog is showing:
Application.Instance.AsyncInvoke(() => { /* do your script work here */ });
// fill in about dialog
aboutDialog.ShowDialog(RhinoEtoApp.MainWindow);
Though it really seems like you might want a custom dialog/form for that purpose anyway (e.g. so you can close it after your script is done, add a progress bar, etc). If you want something similar to Etoβs AboutDialog, you can just copy the code for the dialog layout here and change it for your own use.
