Hi all,
When using Eto.Forms.DropDown
items in Eto windows, the Datastore.Insert()
method does not seem to work on MacOS the same as on WindowsOS?
A simple example on windows (attached): Create a single dropdown, and modify the Datastore using Insert()
before displaying it. This all works as expected:
On MacOS though, the identical code does not update the dropdown options:
it does not throw any exception, and there is an Insert()
method, it just doesn’t appear to do anything?
the only workaround I have found on MacOS is to set up the list ahead of time (do any insert
operations while it is a normal python list`) and then assign the finalized list to the DataStore.
Is there a fix that anyone is aware of to get the normal Insert()
to work as expected on both OSs? Any thoughts on why it would not be working as expected on Mac OS?
all the best,
@ed.p.may
dropdown_insert_example.py (1.6 KB)
