Hello
How to remove the new button created?
import Eto.Drawing as drawing
import Eto.Forms as forms
class MyDialog(forms.Dialog):
def __init__(self):
self.Title = 'Add and delete controls'
self.ClientSize = drawing.Size(300, 500)
self.Padding = drawing.Padding(10)
self.Resizable = False
self.buttonAdd = forms.Button(Text = 'Add button')
self.buttonAdd.Click += self.ButtonAddClick
self.buttonRemove = forms.Button(Text = 'Remove button')
self.buttonRemove.Click += self.ButtonRemoveClick
self.layout = forms.DynamicLayout()
self.layout.AddRow(self.buttonAdd, self.buttonRemove)
self.layout.AddRow(None)
self.Content = self.layout
self.count = 0
self.buttons = []
def AddButton(self):
self.count += 1
self.button = forms.Button(Text = 'Add button'+str(self.count))
self.layout.AddRow(self.button)
self.buttons.append(self.button)
self.layout.Create()
def RemoveButton(self):
self.count += 1
self.layout.Remove(self.buttons[-1])
#self.layout.AddRow(None)
def ButtonAddClick(self, sender, e):
self.AddButton()
def ButtonRemoveClick(self, sender, e):
self.RemoveButton()
def TestMyDialog():
dialog = MyDialog()
dialog.ShowModal()
if __name__ == '__main__':
TestMyDialog()
You could try to hide it with “visible” property. It still will be there, but not accesible for user.
Gijs
#3
This seems to work:
def __init__(self):
self.count = 0
self.buttons = []
self.count += 1
self.layout.Clear()
for b in self.buttons:
self.layout.AddRow(b)
if self.count>0:
self.count -= 1
self.buttons.pop()
self.layout.Clear()
self.AddButton()
self.RemoveButton()
def TestMyDialog():
dialog = MyDialog()
dialog.ShowModal()
TestMyDialog()
Thanks , i thought about it as alternative solution
Thank you , yes it work
I will try add more options to use the new buttons
def resetLayout(self):
self.layout.Clear()
self.count += 1
self.resetLayout()
if self.count>0:
self.count -= 1
self.buttons.pop()
self.resetLayout()
