I’m just beginning to work with the Evolute Primer and I’m having difficulties with the ET Set Reference component. I’m on the first example for the primer and when I attempt to set the reference surface I get the following error:
Creating reference mesh…
Error merging vertices of mesh.
CreateUpdateEvoluteReferenceUserData: Error: A problem occured when meshing the reference surface. Please manually mesh it using _Mesh.
Failed to discretize reference geometry.
I tried taking the surface and changing it to a mesh first and then set the reference, but it does not work. I’m using Rhino 5 x64.
Sorry… this has probably been answered already, but I’ll answer my problem myself. I changed the document tolerance and it worked correctly. Thank you!
