Esc Key -- Not Cancelling -- V5 vs V6
as far as I can gather, this problem occurs with commands that you can pre-select geometry or post-select.
for example:
ExtrudeCrv
OffsetSrf
in V5, if you call ExtrudeCrv with no curves selected yet, then push Esc… the command will cancel…
(it will also cancel if you have pre-selected geometry)
in V6, if you call ExtrudeCrv with no curves selected, then push Esc… nothing happens (except the error sound)…
it will cancel if you have preselected curves.
expected behavior is that the Esc key will cancel the command regardless of pre or post selected geometry.
as a sidenote, it appears to have something to do with the focus of the dialog popup? because if I run the command with no curve preselected, then hover the cursor over the dialog box… Esc will then cancel the command.
thx.
add-- if it matters, I’m using these Theme preferences:
Yes, I can confirm this. ESC only works when hovering the cursor over the dialog box, when it should work all the time. Seems to happen when there are no options present in the command dialog, e.g. Rotate, Move, etc…
I’m also using the floating dialog.
