Errors when rendering a context
good evening, I’m a university student of architecture and I’m experiencing errors when rendering a context.
The 3d model is composed of polysurfaces and as you can see from the image they do not render well.
I thank you, I hope I can find a solution.
HELP-PLZ
Hi Giorgio -
Please run the Rhino SystemInfo command and copy-paste the result here.
As a general comment, it’s somewhat difficult to be able to diagnose a problem just from pictures. It’s much more useful to upload a (part of) your file.
Is your geometry located very far from the origin? If so, moving it closer to the origin might clear that up.
Also, which rendering engine are you using?
Thank you for the information,
I see that you placed the edge of your model at (0,0,0) of the CPLANE not the world you current CPlane origin is 5286610.815 meters from the origin, so I’d first switch to the world CPlane the move your context to the world’s origin. This solved your problem.
Thank you very much :),
I Will try and the i Will let you know.
How can i move the model to the original origin?
Java a good evening.
Use the _Cplane command , then pick the option World.
Select all and use the move command. Make sure you don’t have any hidden objects or layers.
Thank you so much for the help you saved me!
Is there a way to give you a positive review?
Thank you @Giorgio_Parducci for your nice words.
You are welcome, the best thing you can do is to stay involved in our community so you can be part of us.
Thank you so much! I Will! :slight_smile:
