ErrorMessage: Rhino.Geometry.Brep.CreatePlanarBreps(Rhino.Geometry.Curve) is outdated
Hello.
I’m a beginner in developing grasshopper components in Visual Studio and I have quite a hard time getting the syntax of the RhinoCommon library right.
I’m trying to use:
////https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Brep_CreatePlanarBreps_1.htm
public static Brep CreatePlanarBreps(Curve inputLoop)
Using the method, I’ getting the error message:
  1. Warning (CS0618): ‘Rhino.Geometry.Brep.CreatePlanarBreps(Rhino.Geometry.Curve)’ ist veraltet: ‘Use version that takes tolerance as input’ (line 57)
(veraltet means outdated)
191228_00_c#-code-samples_create-planar-breps.gh (6.0 KB)
Sometimes the method works, but I get this error message anyway.
It seems the method I´m using is outdated, but I took the method out of the RhinoCommon library.
I have attached the gh file, including my code definition in C#.
Does anybody know, what I´m doing wrong?
Best wishes,
Oliver
Use the methods which require a tolerance
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Brep_CreatePlanarBreps_4.htm
Thank you,
Michael!
